搜尋
2D 製圖
Clean Slate - BricsCAD Factory Default - Tuesday Tips
By Rose Barfield 3 分鐘 2020年10月19日
Whilst it is great to be able to customize BricsCAD to your heart's content. Sometimes you might simply want to do a hard reset and revert back to BricsCAD's factory default settings.
Restore BricsCAD Settings to Factory Default
In the settings menu, any setting that has been changed from the factory default will be colored blue.
To revert back to default:
  1. Right-click on the setting that has been changed.
  2. Select "Restore default value".
Clean Slate - BricsCAD Factory Default- restore-to-default-768x620
Default BricsCAD Workspaces
If you've had enough of your custom BricsCAD workspace you can do a "factory reset" and go back to BricsCAD default settings.
To return to BricsCAD default workspaces:
  1. Open the Customize dialog box. Right-click outside the drawing area and select Customize... from the drop-down menu.Clean Slate - BricsCAD Factory Default- Customize workspace-800x465
  2. Select the Workspaces tab.
  3. Click Manage your customizations...
  4. Click Revert to defaults. Clean Slate - BricsCAD Factory Default- revert workspaces-768x703
  5. You might need to restart BricsCAD.
Restore BricsCAD version
If you were testing BricsCAD versions using the RunAsLevel command, you might want to go back to BricsCAD Ultimate.
To unlock all the features of BricsCAD Ultimate:
  1. Enter RunAsLevel into the Command line. The following text will appear:
    Change license level for product BricsCAD/Communicator BricsCAD:
  2. Choose BricsCAD. The following text will appear:
    Run BricsCAD as Classic/Pro/PLatinum/Bim/Mechanical/Ultimate Ultimate:
  3. Choose Ultimate.
  4. Restart BricsCAD to apply the changes.
You will now be able to use BricsCAD at the selected license level.
Note: You will only be able to access the BricsCAD Ultimate if you are on the free, 30-day trial, or if you have a valid license.
More Tips:
Explore BricsCAD
Rose Barfield
LinkedIn logo (b&w)
Rose負責收集用戶反饋並改進BricsCAD產品。在來到BricsCAD之前,她是一名CAD使用者,在汽車、航空航太和國防工業中擔任技術插圖員。她喜歡找出事物的工作原理,把它們拆開,並(希望)把它們重新組裝起來。
2024年7月8日 1 分鐘
使用 BricsCAD ® 機械 V24 簡化工程生產材料
裝配技術人員需要一套完整的生產材料才能有效地完成他們的工作。 這些材料的建立必須盡可能簡單,以確保從工程師到技術插畫家的每個人都能有效率、準確地發揮自己的作用。 使用 BricsCAD ® 機械 V24,產生這些材料非常簡單。
2024年6月10日 1 分鐘
使用 BricsCAD 機械 V24 進行逆向工程
在快速發展的機械設計和製造領域中,要保持領先就必須採用能簡化和強化設計流程的工具。BricsCAD 機械 V24 在這方面改變了遊戲規則,尤其是其尖端的逆向工程功能。本部落格深入探討了 BricsCAD 機械 V24 如何透過化繁為簡、化不可能為可能來增強設計流程。
2024年6月10日 1 分鐘
5 Reasons why you need BricsCAD® Lite
Your choice of CAD software significantly impacts your design process, productivity, and, ultimately, the success of your projects. If you're in the market for robust yet intuitive 2D CAD software, look no further than BricsCAD® Lite! Here are five reasons to choose BricsCAD® Lite for your 2D drafting and design projects.
在社交媒體上關注我們
