검색
문서 관리
By The Bricsys Team 4 min 2024년 11월 6일
document management in construction
Document Management in Construction
add documentation LB Aproplan (1)
Alongside document management, review processes are a challenge construction professionals contend with. Ensuring all stakeholders are aligned with any issues, required updates, or changes is vital for running a project efficiently.With Bricsys 24/7 and LB Aproplan, users can add images, comments and statuses to documents, raising the flag on any problems so that everyone is on the same page since all information is accessible in real-time!
User Access and Role Management
Bricsys 24/7 has precise user access management. Users can see documents and other features of the platform based on their role. Administrators can assign access rights to users and manage folder synchronization. You must be an administrator to activate synchronization between Bricsys 24/7 and AproPlan, ensuring controlled document access. Both platforms allow users to manage visibility and access rights, ensuring relevant team members can access specific documents.
Synchronize Project Data Seamlessly
efficient document management
To run a project efficiently, you need organized data, and a highlight of this integration is how effortless it makes aligning project data between the two platforms. When you synchronize the two, the integration ensures that the information available in LB Aproplan accurately reflects the data in Bricsys 24/7—in real-time. It also offers transparency with document versioning and audit trails while maintaining complete control over which documents and folders you want to synchronize.
This centralized approach to document management, working from a “single source of truth,” enhances the accuracy and accessibility of critical project data so teams can focus more on implementation and less on administration.
Enhanced Collaboration
approval workflow LB 247 1
Any construction project involves multiple stakeholders, so effective collaboration ensures its success. Integrating Bricsys 24/7 and LB Aproplan makes collaboration easy by optimizing the design review process and fostering communication and collaboration between designers and project stakeholders. Enhanced collaboration means the project team is aligned and clarifies any potential issues early. Design changes or details are instantly shared, so everyone involved is always up-to-date with the latest updates, streamlining project management.
Better Decision-Making Processes and Risk Mitigation
LB add status (1)
The increased visibility of project documentation and data within a single, unified platform gives project managers a panoramic view of the project. This insight is instrumental for risk management, decision-making processes, and tracking a project’s trajectory. Accurate, real-time documentation and transparent reporting empower project leaders to make timely, informed decisions. Early detection of potential issues allows the team to proactively develop strategies to tackle them, reducing risk and preventing minor issues from escalating into major problems.
Maximizing ROI with Streamlined On-Site Operations
Construction projects require substantial time, money, and material resources. Integrating LB Aproplan with Bricsys 24/7 maximizes returns on these resources by streamlining on-site operations. Real-time access to project documents and reviews minimizes downtime and increases efficiency. This enables more productive use of labour and materials and significantly reduces the cost of rework. For construction project managers seeking a solution to improve delivery timelines, promote agile communication and ensure each team member is on the same page, this integration between Bricsys 24/7 and LB Aproplan is ideal.
Learn more about LB Aproplan.
Learn more about Bricsys 24/7.
Watch the webinar (available in Dutch or French) on the Bricsys YouTube channel!
2024년 11월 6일 4 min
2024년 9월 17일 3 min
브릭스캐드에서 선 유형 사용자 지정
BricsCAD에서 사용자 지정 선 유형을 만들면 도면의 디테일과 선명도를 크게 향상시킬 수 있습니다. 복잡한 엔지니어링 계획이든 단순한 레이아웃 디자인이든, 자신만의 라인 유형을 만드는 방법을 이해하면 프로젝트에 전문성을 부여할 수 있습니다. 이 단계별 가이드를 따라 BricsCAD에서 간단한 선 유형과 복잡한 선 유형을 만드는 방법을 배우세요.
2024년 9월 10일 2 min
토목 및 측량 워크플로우를 위한 BricsCAD 파트너 앱
브릭시스는 전문 측량 및 토목 앱 개발자가 BricsCAD 사용자에게 강력하고 효율적인 워크플로우를 제공하는 전문 토목 및 측량 도구를 개발할 수 있도록 탄탄한 기반을 제공합니다. 다양한 개발자 파트너가 BricsCAD V24의 토목 및 측량 워크플로우를 보완하기 위해 어떤 업데이트와 개선 사항을 적용했는지 살펴보세요.
이러한 토목 및 측량 애플리케이션은 BricsCAD에서 지원하는 여러 타사 애플리케이션 중 하나이며, 개발자들은 기능을 개선하고 매 릴리스마다 도입되는 새로운 기능에 발맞추기 위해 노력하고 있습니다.
소셜 미디어에서 팔로우하기
