3D 모델링
How to Model a Chess Set - Easy Builds
By Rose Barfield 4 min 2020년 5월 21일
In this series, you will learn how to work with CAD by following easy projects. Use only simple commands to build almost anything! For this tutorial, learn how to make a chess set.
How to Model a Chess Set in BricsCAD
Time to complete: 1-2 Hours
Difficulty: 6/10
Commands used:
Extrude
Manipulate
DmRevolve
DmPushPull
Offset
Mirror
Chamfer
Fillet
ArrayPolar
Explode
Subtract
Tutorial: Model a Chess Set in BricsCAD
  1. Start by drawing the outline of half a Pawn.
    Tip Use use polylines when possible.
  2. Then, Trim the excess linework and Join to create a closed polygon. How to Model a Chess Set - Easy Builds- pawn outline-199x300
  3. Use the Manipulator to copy the outline.How to Model a Chess Set - Easy Builds- Copy-1024x392
  4. Use these copies as a guide and modify until you have something that looks like this:
    How to Model a Chess Set - Easy Builds- Outlines
    Feel free to copy this image into BricsCAD and trace it.
  5. Use DmRevolve to convert the outline into a solid.How to Model a Chess Set - Easy Builds- revolve-1024x569
  6. Repeat for the other pieces. You should now have something that looks like this:How to Model a Chess Set - Easy Builds- dmrevolve-e1588864999998-1024x445
  7. Create the slot on the Bishop:
    1. Extrude a rectangle. Use the Both sides option (Command line) and the Subtract mode.
      To change the mode hit Ctrl. (See the Hotkey Assistant).How to Model a Chess Set - Easy Builds- extrude
    2. (Optional) Use DmPushPull to edit the slot.
  8. To create the battlements on the Rook:
    1. Offset the edge of the top face.How to Model a Chess Set - Easy Builds- offset
    2. Extrude down.How to Model a Chess Set - Easy Builds- extrude rook1
    3. Extrude rectangles to create the crenels. Use the Both sides option (Command line) and the Subtract mode.
      To change the mode hit Ctrl. (See the Hotkey Assistant).How to Model a Chess Set - Easy Builds- extude rook
  9. To create the Knight:
    1. Extrude the horsehead shape.How to Model a Chess Set - Easy Builds- extrude horse-1-e1588865198680
    2. Move the ear to the edge of the solid.How to Model a Chess Set - Easy Builds- ear
    3. Mirror the ear.How to Model a Chess Set - Easy Builds- mirror ear
    4. Extrude both ears. Leave a gap in the middle.
    5. Chamfer the edges.How to Model a Chess Set - Easy Builds- fillet
    6. Extrude the eye.How to Model a Chess Set - Easy Builds- eye
    7. Fillet the edges.How to Model a Chess Set - Easy Builds- Chamfer
  10. For the Queen:
    1. Add 2 spheres stacked on top of each other.How to Model a Chess Set - Easy Builds- queen 2
    2. Create a cylinder.How to Model a Chess Set - Easy Builds- cylinder
    3. Array the cylinder in the polar mode. Set the axis to Y and set the center point to the center of the Queen.How to Model a Chess Set - Easy Builds- polar array-1024x564
    4. Explode the Array.
    5. Subtract the cylinders from the Queen. You should now have something like this:How to Model a Chess Set - Easy Builds- Queen crown-e1588865375870
  11. For the King:
    1. Extrude the shapes to make the cross.How to Model a Chess Set - Easy Builds- Cross
    2. Create a Cylinder on top.
    3. Finish with a Sphere.
    4. Fillet the edges.How to Model a Chess Set - Easy Builds- fillete-1024x631
      You should now have something that looks like this:How to Model a Chess Set - Easy Builds- end-result-1024x477
  12. (Optional) To finish, add materials and render with the BricsCAD Enscape Integration.
    How to Model a Chess Set - Easy Builds- animation
    Once you have completed this tutorial to model a chess set you should have something that looks like this.
Download BricsCAD free for 30-days
Get started with this model chess set tutorial in BricsCAD
Permanent or subscription licenses that work in all languages, in all regions.
Enscape for BricsCAD will be discontinued and taken down from the Bricsys App Store on 22/10/2023. All active subscriptions purchased before this date will keep receiving support until the subscription expires. Bricsys will provide a version of “Enscape for BricsCAD” that will be compatible with BricsCAD v24.1 If you have any questions please click the “Contact” button in the App Store and create a Support Request.
Rose Barfield
LinkedIn logo (b&w)
Rose는 사용자 의견을 수렴하고 BricsCAD 제품을 개선하는 일을 담당하고 있습니다. BricsCAD에 입사하기 전에는 CAD 사용자였으며 자동차, 항공 우주 및 방위 산업에서 테크니컬 일러스트레이터로 근무했습니다. 그녀는 사물이 어떻게 작동하는지 알아내고, 분해하고 (잘하면) 다시 조립하는 것을 좋아합니다.
2024년 6월 10일 4 min
5 Reasons why you need BricsCAD® Lite
Your choice of CAD software significantly impacts your design process, productivity, and, ultimately, the success of your projects. If you're in the market for robust yet intuitive 2D CAD software, look no further than BricsCAD® Lite! Here are five reasons to choose BricsCAD® Lite for your 2D drafting and design projects.
2024년 6월 10일 4 min
Reverse Engineering with BricsCAD Mechanical V24
In the rapidly evolving field of mechanical design and manufacturing, staying ahead means adopting tools that simplify and enhance the design process. BricsCAD Mechanical V24 emerges as a game-changer in this respect, particularly with its cutting-edge Reverse Engineering capabilities. This blog delves into how BricsCAD Mechanical V24 is enhancing the design process by making the complex simple and the impossible, possible.
2024년 6월 3일 3 min
What's New in BricsCAD® Mechanical V24.2?
BricsCAD® Mechanical V24.2 is here, helping manufacturers of all sizes fast-track their way to complete and accurate production materials. In the latest BricsCAD release, we've honed in on two crucial areas: workflow compatibility with other CAD software like AutoCAD® Mechanical and simplifying the assembly inspection and instruction capabilities. So, let's explore what's new!
소셜 미디어에서 팔로우하기
