BricsCAD® Mechanical V20 offers new and extended workflows for 3D direct parametric modeling, assembly and sheet metal design. As a part of the BricsCAD® Ultimate suite, it offers more than "just" MCAD tools. BricsCAD® Mechanical V20 provides a seamless bridge between MCAD and BIM, facilitating the design and detailing of manufactured building products. No other CAD product -- DWG-based or otherwise -- can make this claim.
Watch video on YouTube
BOM panel and Exploded Views
To speed the layout of Bills of Materials (BOM), the interactive BOM panel helps you create and format BOM tables faster and more accurately. Significantly enhanced in V20, the powerful Exploded View capability of BricsCAD® Mechanical V20 creates multi-axis disassembly views with automatically generated trailing lines. And of course, automated tagging links your exploded views with their corresponding BOM tables.
New parametric capabilities
BricsCAD® Mechanical advances its parametric capabilities with geometry-driven constraints, path constraints, and a new, parametric suppression feature. Add these new capabilities with the addition of multi-parametric, keyframed animations, and you'll visualize your designs faster than ever before.
"I believe that BricsCAD® Mechanical V20 is another solid step towards a full-scale solution for designing mechanical products in 3D, in a unified .dwg environment. The main highlight is its integration with BricsCAD® BIM in one BricsCAD® Ultimate product -- a workflow that has no analogs in any other product," -- Dmitry Ushakov, CEO at Bricsys Technologies Russia.
Fast generation of draft quality drawing views
New drawing layout tools let you create draft quality drawing views up to ten times faster than before. This lets you create multiple sheets containing multiple layouts, in real-time -- while the documentation-quality views regenerate later.
Hems and Tabs
In BricsCAD® Mechanical V20, we're offering two new types of sheet metal features: hems and tabs, to align and connect sheet metal components quickly and accurately. Both hem and tab features are controlled parametrically in V20.
Test the best MCAD software today!
Permanent or subscription licenses that work in all languages, in all regions.
Free BricsCAD Ultimate 30-day trial
Keep Reading:
Contact information Don Strimbu +1(0)415 250-3265 press@bricsys.com
