검색
BIM TipsBIM BricsCAD BIM2D 팁3D 팁
BricsCAD BIM에서 BIMIFY를 사용하는 방법
By Rose Barfield 2 min 2023년 1월 23일
What if I told you that you could generate section and elevation views and add BIM data to a 3D model, all with a single click? Don’t believe me? Then try BIMIFY for yourself!
bimify short
What is BIMIFY?
BIMIFY analyzes the model, automatically classifies building elements, assigns spatial locations, and creates new buildings, stories, and spaces. Optionally, it also makes plan sections and elevations. All with a single click!
How do I use BIMIFY in BricsCAD?
To use BIMIFY:
bimify model
Start with a drawing that contains a 3D model of a building.
Enter BIMIFY
bimify command panel
In the command panel, set which entities are classified and how.
Click Apply
Yes, it is that easy.
What license level do I need to access the BIMIFY command?
You will need BricsCAD BIM or higher to access the BIMIFY command.
Get started with BricsCAD today!
Buy BricsCAD from the e-store or download the 30-day free trial now and discover how you can accelerate your time to deliverable with BricsCAD.
Have you tried the BIMIFY command and have any ideas or suggestions?
Fantastic! We love hearing your thoughts on BricsCAD® – all feedback is welcome, whether good or bad. The best way to let us know what you think about BricsCAD or features like BIMIFY is to send us a support request and our support team will be happy to help.
Want more BricsCAD Tips and Tricks?
If you’re curious about other BricsCAD tips and tricks, check out our YouTube channel to learn more about BricsCAD’s features and commands, or take a peek at the rest of the Bricsys blog.
Rose Barfield
LinkedIn logo (b&w)
Rose는 사용자 의견을 수렴하고 BricsCAD 제품을 개선하는 일을 담당하고 있습니다. BricsCAD에 입사하기 전에는 CAD 사용자였으며 자동차, 항공 우주 및 방위 산업에서 테크니컬 일러스트레이터로 근무했습니다. 그녀는 사물이 어떻게 작동하는지 알아내고, 분해하고 (잘하면) 다시 조립하는 것을 좋아합니다.
소셜 미디어에서 팔로우하기
