Search
2D Drafting3D ModellingBIMManufacturing & Mechanical
Converting PDF to DWG files with BricsCAD®
By The Bricsys Team 6 min 2. oktoober 2023
You can convert PDF files to DWG files quickly and easily in BricsCAD®. When you convert a PDF to a DWG file, BricsCAD® converts straight lines to polylines, true type fonts to MTEXT, and filled solids to hatches, giving you a working drawing file in place of your PDF! Here's how you can do it!
How to create a PDF underlay in BricsCAD®
In this example, we want to convert a PDF file of a house plan to a drawing file.
PDF Exported
You can create a PDF underlay to attach a PDF file to your current drawing.
  • Click on the Insert tab.
  • Click on the Attach PDF button.
  • Select the PDF file and click on Open.
  • Now, the Attach PDF Underlay dialog box appears.
PDF Underlay Dialog
  • Use the dialog to specify the insertion point, scale factor, and rotation angle.
  • Click on OK.
  • Pick a point to specify the insertion point.
PDF insertion point
  • Now you've inserted the PDF file.
  • Double-tap the scroll wheel of the mouse to zoom out.
You have attached the PDF file as an underlay into the current drawing.
PDF added as underlay
  • Click on the PDFs fly out.
  • Click on PDF underlays.
Now you can see the PDF underlays interface in the drawing explorer. The drawing explorer shows a list of PDF underlays in the drawing alongside information like file size, date, and saved path. It also displays a preview of the PDF file.
Drawing Explorer PDF Underlay
How to convert PDF files to drawing files in BricsCAD
You can convert this PDF file to a drawing file in various ways. For that, you can use the PDF import command. You can access this command in different ways.
  • Click on the Bricsys application button on the top left corner of your screen.
PDF Import Button
  • Click on Import.
  • Click on Import PDF.
  • Go to the Insert tab.
  • Click on the Import PDF button.
  • Enter the PDFIMPORT command using your keyboard.
In BricsCAD, you can convert PDF to CAD entities in two ways.
Method 1: Select PDF underlay
Select PDF Underlay
  • Click on the PDF underlay.
You can choose to convert the entire area in the underlay to CAD entities or define an area in the PDF underlay using a rectangle or a polygon.
  • To choose a rectangular area, click on the first corner and then its opposite corner.
  • The polygonal option defines the conversion area using a polygon.
  • Or you can use the ALL option – this selects all the entities in the PDF underlay to be converted to CAD entities.
If you choose the Settings option, the settings dialog box will appear.
In this dialog, you can choose what data you want to import.
PDF Settings box
  • Click on the layers option to Use PDF layers. All the layers in the PDF are available here.
When you choose Layer per Entity Type, each entity type is kept in a separate layer. If you choose "Use current layer," only the current layer is used, and new layers won't be created. In this example, we chose "Use PDF layers".
Now, you can import the vector geometry, solid fills, true type text, raster images, and raster images folder. You can also expand the PDF Import Options menu to see several additional options.
In this example, we chose ALL as we want the entire PDF underlay converted to a CAD drawing. Now, you're presented with three options: keep, detach, and unload.
Keep Detach Unload
Keep: keeps the PDF underlay and converts its vector portions to CAD entities.
Detach: completely detaches the PDF underlay from the drawing, and it will not be shown.
Unload: Unload the PDF underlay so that it is no longer seen in the drawing but is still attached to the drawing.
In this example, we chose to keep the PDF underlay and the converted drawing.
When you move the PDF underlay, you'll see both the underlay and the converted drawing on the screen.
Underlay and Drawing
If you check the drawing now, you'll see that the straight lines were converted to polylines, true type fonts were converted to multiline text, solid fills were converted to hatches, and layers in the PDF file were converted to layers in the CAD drawing.
To use the Detach option:
  • Select the PDF underlay.
  • Click on ALL to select the entire underlay.
  • Click on Detach, and you'll see that the PDF underlay is detached from the drawing, and the drawing is created. Click on the PDF fly-out.
  • Click on PDF underlays, and the underlay is no longer listed as it is detached.
To use the unload option:
  • Click on All
  • Then click on Unload, and you'll see that the PDF underlay is unloaded, and while it is no longer seen in the drawing, it is still attached to the drawing.
  • Click on PDF fly-out.
  • Click on PDF Underlay, and you'll see the PDF underlay here, but it is not seen in the drawing.
  • To insert the underlay to a different location in the drawing, select the PDF underlay.
  • Click on the Insert button.
Method 2: Import PDF
You can import a PDF file directly into the current drawing.
  • Click on the file option.
  • Select the PDF file you want to import.
  • When you have a PDF with numerous pages, you can choose which page(s) you want to import.
  • Pick a point to specify the insertion point, and you can set a scale factor if required, and a rotation angle.
  • Double-click the scroll wheel of the mouse to zoom.
You have now successfully converted the PDF to a drawing file!
Watch the video!
Check out the YouTube tutorial to see how you can convert PDF files to DWG files in BricsCAD.
Get started with BricsCAD today!
Buy BricsCAD or download the 30-day free trial now and discover how you can accelerate your time to deliverable with BricsCAD.
Have you used BricsCAD and have some ideas or suggestions?
Fantastic! We love hearing your thoughts on BricsCAD® – all feedback is welcome, whether good or bad. The best way to tell us what you think about BricsCAD is to send us a support request; our support team will gladly help.
Want more BricsCAD tips and tricks?
If you're curious about what else you can do in BricsCAD, check out our YouTube channel to learn more about BricsCAD's features and commands, or take a peek at the rest of the Bricsys blog.
2. oktoober 2023 5 min
BricsCAD® for 3D: Visual Styles
When you're working with 3D models in BricsCAD®, you can use visual styles to control the display of 3D solids and surfaces to make those final touches on your designs. Let's take a look at how you can use visual styles in BricsCAD.
20. september 2023 5 min
Getting Started with BricsCAD®: Trial and Licensing Options
Are you considering BricsCAD? Then, you're probably wondering what licensing options are available when you choose BricsCAD. You can avail of the free 30-day trial to try BricsCAD and its various versions to decide which edition suits your needs best. When you buy BricsCAD, you can choose from our flexible licensing options. Let's take a look at the different licensing options!
14. september 2023 7 min
BricsCAD® for 3D: Creating a 3D Model
You can create 3D models in BricsCAD® quickly and easily using BricsCAD's familiar tools and 3D workflows. Let's take a look at how you can create 3D models in BricsCAD and get acquainted with some simple modeling tools and UCS applications - starting with this straightforward mechanical component!
Follow us on social media
