Buscar
Dibujo 2DModelado 3DMechanical
What's New in BricsCAD® Mechanical V24.2?
Por The Bricsys Team 3 min 3 de junio de 2024
BricsCAD® Mechanical V24.2 is here, helping manufacturers of all sizes fast-track their way to complete and accurate production materials. In the latest BricsCAD release, we've honed in on two crucial areas: workflow compatibility with other CAD software like AutoCAD® Mechanical and simplifying the assembly inspection and instruction capabilities. So, let's explore what's new!
Enhanced Interoperability
Part reference BricsCAD
With the V24.2 update, we've prioritized workflow compatibility with other CAD software, like AutoCAD® Mechanical, to further cater to users transitioning to BricsCAD and those integrating their existing DWG libraries. We've simplified creating multiple instances of part references; now, you can reference an existing part to avoid manual recreation. All new part references are associative with the existing parts list, amplifying efficiency and accuracy.
Introducing BricsCAD's Balloon Annotations
AMBALLOON balloon annotation BricsCAD
BricsCAD now introduces the AMBALLOON command, a new feature that enables balloon annotations. This addition boosts BricsCAD Mechanical's interoperability, familiarizing it further with AutoCAD® Mechanical. You can organize balloons using predefined vertical and horizontal placements or customized angle placements for a personalized touch.
New and Improved Part Reference Features
Part ref dialog
BricsCAD has added innovative features to its part reference toolkit. Now, there's an option to reference an existing BricsCAD block, automatically transferring the metadata from the block to the part reference. The newly introduced AMPARTREF command dialog makes updating your part references a breeze.
Customizable Bill of Materials
BricsCAD Mechanical
The new V24.2 version has improved your Bill of Materials (BOM) workflow by introducing a dialog box for a more flexible configuration. Editing part property values and setting incremental or fixed values for a range of cells is now ultra-intuitive.
3D to 2D Automation Tools – A Shortcut to Production-Readiness!
BricsCAD Mechanical V24.2 seamlessly transitions from 3D to 2D. It streamlines the creation of production-ready materials through automation tools that quickly move designs from prototyping to the production stage. These enhancements save extensive time and dramatically boost efficiency.
Assembly Inspection for Gravitational Stability
BricsCAD Mechanical V24.2 introduces gravitational stability in its assembly inspection. It identifies whether the component would remain gravitationally stable before fastening reduces the chances of error. Insights gained from these results can guide design changes, optimizing the assembly instructions for maximum efficiency.
Streamlining Documentation with BMEXPLODE command
BMEXPLODE has seen significant updates in the V24.2 version. This feature permits the creation of exploded views with a custom camera orientation based on each sequence step, highlighting critical details for effective communication. Subsequently, using the EXPORTSVG command, these views can be exported as SVG files for better scalability and editing capabilities—perfect for word-processing applications for creating assembly manuals.
BricsCAD® Mechanical V24.2 truly integrates customization, interoperability, and efficiency, promising a smoother transition for new users and an enhanced working landscape for existing ones.
Want to learn more about BricsCAD® Mechanical V24.2?
If you're curious about what else you can do in BricsCAD Mechanical V24.2, check out our YouTube channel or take a peek at the rest of the Bricsys blog to learn more!
Have you used BricsCAD® Mechanical V24.2 and have some ideas or suggestions?
Fantastic! We love hearing your thoughts on BricsCAD® – all feedback is welcome, whether good or bad. The best way to tell us what you think about BricsCAD is to send us a support request; our support team will gladly help.
Get started with BricsCAD® Mechanical V24.2 today!
Buy BricsCAD or download the 30-day free trial now and discover how you can accelerate your time to deliverable with BricsCAD.
19 de marzo de 2024 9 min
Novedades de BricsCAD® V24.2
BricsCAD® V24.2 está repleto de funciones nuevas y mejoradas para el dibujo 2D, el modelado 3D, los flujos de trabajo civiles, topográficos, BIM y mecánicos. Con esta versión, el equipo de Bricsys incluyó varias funciones y mejoras nuevas para ayudarlo a acelerar el tiempo de entrega y brindarle una experiencia CAD familiar. Entonces, ¡profundicemos y exploremos las novedades de BricsCAD V24.2!
23 de noviembre de 2023 7 min
BricsCAD V24: ¿qué hay de nuevo en BricsCAD® Mechanical?
Desarrollamos BricsCAD® Mechanical V24 teniendo en cuenta las necesidades de nuestros usuarios, por lo que incluimos funciones muy solicitadas para brindarle un conjunto completo de herramientas de diseño y dibujo que sea familiar y compatible con su software actual. ¡Veamos las novedades de BricsCAD® Mechanical V24!
26 de octubre de 2023 5 min
¿Qué hay de nuevo en BricsCAD® V24?
¡Bienvenido a BricsCAD® V24! El CAD profesional sin compromiso. Esta versión incluye nuevas funciones y actualizaciones, lo que facilita el aprendizaje, el uso y la adopción de BricsCAD. ¡Echemos un vistazo a las novedades de BricsCAD V24!
Síganos en las redes sociales
