2D Drafting3D Modelling
BricsCAD: Discover the Difference: Easily Change Geometry with the Manipulator
By Gavin England 3 min 23. september 2022
1_Manipulator_at_your_Cursor
Welcome back to our ‘BricsCAD: Discover the Difference’ series. This week we’re showing you another intuitive tool to replace legacy-CAD systems. Today, you can see how users are enjoying more for creativity with a visual manipulator tool for direct modelling in your workflows.
2_Mainuplator_Launch
Multiple manipulations in CAD and direct modeling
In our CAD solution, the Manipulator is a visual tool to give users dynamic movement, rotation, mirroring and scaling of selected geometry, without any command input. Have you tried it yet? For multiple manipulations, it is far more convenient than using a combination of other functions, such as move and rotate.
Even better, the Manipulator tool is intuitively easy to use, and when used in conjunction with direct modelling tools, it is also a powerful way to model shapes.
3_Manipulator_Rotate
Standard displacement commands at your cursor
All the standard geometry tools are available in one convenient tool at your cursor. Select an entity, and the manipulator appears. Use the axes to move along either axis or move using both axes at the same time.
Use the rotation bar to rotate freely or type in precise values. You can work with single objects or change groups of entities at once. The Manipulator anchor point can be moved as you wish, giving you more control over your design.
4_Manipulator_Dynamic_Ruler
Dynamic ruler: Flexible, Precise and Easy
The ruler increments change dynamically. This means you can work accurately at any scale, and you can easily copy or repeat items during a rotate or move command. This capability streamlines your workflow to work quickly and easily in the way you need to.
5_Manipulator_Solids
A Manipulator tool for 2D or 3D
The Manipulator works in both 2D and 3D. This lets you snap to elements, and move and rotate them in multiple planes. You can even move entire 3D solids, as you would with 2D entities, and you can combine the Manipulator with faces and edges and direct modeling abilities to model faster.
6_Manipulator_Benefits
The Manipulator is just one of the advanced and intelligent tools in BricsCAD. We have many more insights for getting the most from your workflows, so keep digging into our blogs. And, in the meantime, why not discover the BricsCAD difference yourself? Start your free trial today.
Visit our migration page for more information on how easy it is to move to BricsCAD
by Gavin England - Product Marketing Manager
A qualified Mechanical Engineer, Gavin spent the early part of his career working in various design teams, helping to develop products as diverse as materials handling equipment and rally cars. The last twenty years have been spent in organisations such as IBM, Siemens and Autodesk, promoting and marketing CAD, PLM and related solutions, primarily to the manufacturing industry. An advocate of the benefits of innovate design technology, Gavin works in the Bricsys Go To Market team, focused on helping our customers understand the unique value of BricsCAD Pro, Lite and Mechanical, particularly within the manufacturing industry.
10. juni 2024 4 min
5 Reasons why you need BricsCAD® Lite
Your choice of CAD software significantly impacts your design process, productivity, and, ultimately, the success of your projects. If you're in the market for robust yet intuitive 2D CAD software, look no further than BricsCAD® Lite! Here are five reasons to choose BricsCAD® Lite for your 2D drafting and design projects.
10. juni 2024 4 min
Reverse Engineering with BricsCAD Mechanical V24
In the rapidly evolving field of mechanical design and manufacturing, staying ahead means adopting tools that simplify and enhance the design process. BricsCAD Mechanical V24 emerges as a game-changer in this respect, particularly with its cutting-edge Reverse Engineering capabilities. This blog delves into how BricsCAD Mechanical V24 is enhancing the design process by making the complex simple and the impossible, possible.
3. juni 2024 3 min
What's New in BricsCAD® Mechanical V24.2?
BricsCAD® Mechanical V24.2 is here, helping manufacturers of all sizes fast-track their way to complete and accurate production materials. In the latest BricsCAD release, we've honed in on two crucial areas: workflow compatibility with other CAD software like AutoCAD® Mechanical and simplifying the assembly inspection and instruction capabilities. So, let's explore what's new!
Follow us on social media
