Pesquisar
Gerenciamento de Documentos
Por The Bricsys Team 4 min 6 de novembro de 2024
document management in construction
Document Management in Construction
add documentation LB Aproplan (1)
Alongside document management, review processes are a challenge construction professionals contend with. Ensuring all stakeholders are aligned with any issues, required updates, or changes is vital for running a project efficiently.With Bricsys 24/7 and LB Aproplan, users can add images, comments and statuses to documents, raising the flag on any problems so that everyone is on the same page since all information is accessible in real-time!
User Access and Role Management
Bricsys 24/7 has precise user access management. Users can see documents and other features of the platform based on their role. Administrators can assign access rights to users and manage folder synchronization. You must be an administrator to activate synchronization between Bricsys 24/7 and AproPlan, ensuring controlled document access. Both platforms allow users to manage visibility and access rights, ensuring relevant team members can access specific documents.
Synchronize Project Data Seamlessly
efficient document management
To run a project efficiently, you need organized data, and a highlight of this integration is how effortless it makes aligning project data between the two platforms. When you synchronize the two, the integration ensures that the information available in LB Aproplan accurately reflects the data in Bricsys 24/7—in real-time. It also offers transparency with document versioning and audit trails while maintaining complete control over which documents and folders you want to synchronize.
This centralized approach to document management, working from a “single source of truth,” enhances the accuracy and accessibility of critical project data so teams can focus more on implementation and less on administration.
Enhanced Collaboration
approval workflow LB 247 1
Any construction project involves multiple stakeholders, so effective collaboration ensures its success. Integrating Bricsys 24/7 and LB Aproplan makes collaboration easy by optimizing the design review process and fostering communication and collaboration between designers and project stakeholders. Enhanced collaboration means the project team is aligned and clarifies any potential issues early. Design changes or details are instantly shared, so everyone involved is always up-to-date with the latest updates, streamlining project management.
Better Decision-Making Processes and Risk Mitigation
LB add status (1)
The increased visibility of project documentation and data within a single, unified platform gives project managers a panoramic view of the project. This insight is instrumental for risk management, decision-making processes, and tracking a project’s trajectory. Accurate, real-time documentation and transparent reporting empower project leaders to make timely, informed decisions. Early detection of potential issues allows the team to proactively develop strategies to tackle them, reducing risk and preventing minor issues from escalating into major problems.
Maximizing ROI with Streamlined On-Site Operations
Construction projects require substantial time, money, and material resources. Integrating LB Aproplan with Bricsys 24/7 maximizes returns on these resources by streamlining on-site operations. Real-time access to project documents and reviews minimizes downtime and increases efficiency. This enables more productive use of labour and materials and significantly reduces the cost of rework. For construction project managers seeking a solution to improve delivery timelines, promote agile communication and ensure each team member is on the same page, this integration between Bricsys 24/7 and LB Aproplan is ideal.
Learn more about LB Aproplan.
Learn more about Bricsys 24/7.
Watch the webinar (available in Dutch or French) on the Bricsys YouTube channel!
6 de novembro de 2024 4 min
17 de setembro de 2024 3 min
Personalizar Tipos de Linha no BricsCAD
Criar tipos de linha personalizados no BricsCAD pode melhorar significativamente os detalhes e a clareza de seus desenhos. Se você está trabalhando em plantas complexas de engenharia, ou projetos simples de layout, entender como criar seus próprios tipos de linha pode dar aos seus projetos uma vantagem profissional. Siga este guia passo-a-passo para aprender como criar os tipos de linha simples, e também os complexos, no BricsCAD.
10 de setembro de 2024 3 min
Aplicações de Parceiros do BricsCAD para Fluxos de trabalho de Civil e de Levantamento
Na Bricsys, fornecemos uma base sólida para nossos desenvolvedores especializados de aplicações de Civil e de Levantamento, para criarem ferramentas especialistas em Civil e em Levantamentos que oferecem fluxos de trabalho robustos e eficientes para os usuários do BricsCAD. Vamos ver quais atualizações e melhorias nossos vários parceiros desenvolvedores fizeram para complementar os fluxos de trabalho de Civil e de Levantamento do BricsCAD V24.Essas aplicações de Civil e de Levantamento estão entre as múltiplas aplicações de terceiros suportadas pelo BricsCAD, com nossos desenvolvedores trabalhando para melhorar sua funcionalidade e acompanhar nossos novos recursos introduzidos a cada novo lançamento.
Siga-nos nas mídias sociais
