Szukaj
Zarządzanie dokumentami
Przez The Bricsys Team 4 min 6 listopada 2024
document management in construction
Document Management in Construction
add documentation LB Aproplan (1)
Alongside document management, review processes are a challenge construction professionals contend with. Ensuring all stakeholders are aligned with any issues, required updates, or changes is vital for running a project efficiently.With Bricsys 24/7 and LB Aproplan, users can add images, comments and statuses to documents, raising the flag on any problems so that everyone is on the same page since all information is accessible in real-time!
User Access and Role Management
Bricsys 24/7 has precise user access management. Users can see documents and other features of the platform based on their role. Administrators can assign access rights to users and manage folder synchronization. You must be an administrator to activate synchronization between Bricsys 24/7 and AproPlan, ensuring controlled document access. Both platforms allow users to manage visibility and access rights, ensuring relevant team members can access specific documents.
Synchronize Project Data Seamlessly
efficient document management
To run a project efficiently, you need organized data, and a highlight of this integration is how effortless it makes aligning project data between the two platforms. When you synchronize the two, the integration ensures that the information available in LB Aproplan accurately reflects the data in Bricsys 24/7—in real-time. It also offers transparency with document versioning and audit trails while maintaining complete control over which documents and folders you want to synchronize.
This centralized approach to document management, working from a “single source of truth,” enhances the accuracy and accessibility of critical project data so teams can focus more on implementation and less on administration.
Enhanced Collaboration
approval workflow LB 247 1
Any construction project involves multiple stakeholders, so effective collaboration ensures its success. Integrating Bricsys 24/7 and LB Aproplan makes collaboration easy by optimizing the design review process and fostering communication and collaboration between designers and project stakeholders. Enhanced collaboration means the project team is aligned and clarifies any potential issues early. Design changes or details are instantly shared, so everyone involved is always up-to-date with the latest updates, streamlining project management.
Better Decision-Making Processes and Risk Mitigation
LB add status (1)
The increased visibility of project documentation and data within a single, unified platform gives project managers a panoramic view of the project. This insight is instrumental for risk management, decision-making processes, and tracking a project’s trajectory. Accurate, real-time documentation and transparent reporting empower project leaders to make timely, informed decisions. Early detection of potential issues allows the team to proactively develop strategies to tackle them, reducing risk and preventing minor issues from escalating into major problems.
Maximizing ROI with Streamlined On-Site Operations
Construction projects require substantial time, money, and material resources. Integrating LB Aproplan with Bricsys 24/7 maximizes returns on these resources by streamlining on-site operations. Real-time access to project documents and reviews minimizes downtime and increases efficiency. This enables more productive use of labour and materials and significantly reduces the cost of rework. For construction project managers seeking a solution to improve delivery timelines, promote agile communication and ensure each team member is on the same page, this integration between Bricsys 24/7 and LB Aproplan is ideal.
Learn more about LB Aproplan.
Learn more about Bricsys 24/7.
Watch the webinar (available in Dutch or French) on the Bricsys YouTube channel!
6 listopada 2024 4 min
17 września 2024 3 min
Dostosowywanie Rodzajów Linii w BricsCAD
Tworzenie niestandardowych rodzajów linii w BricsCAD może znacznie zwiększyć szczegółowość i przejrzystość rysunków. Niezależnie od tego, czy pracujesz nad złożonymi planami inżynieryjnymi, czy prostymi projektami układów, zrozumienie, jak tworzyć własne rodzaje linii, może nadać Twoim projektom profesjonalną przewagę. Postępuj zgodnie z tym przewodnikiem krok po kroku, aby dowiedzieć się, jak tworzyć zarówno proste, jak i złożone rodzaje linii w BricsCAD.
10 września 2024 3 min
Aplikacje partnerskie BricsCAD dla cywilnych i geodezyjnych przepływów pracy
W Bricsys zapewniamy solidne podstawy dla naszych wyspecjalizowanych programistów aplikacji geodezyjnych i cywilnych do tworzenia specjalistycznych narzędzi cywilnych i geodezyjnych, które zapewniają solidne i wydajne przepływy pracy dla użytkowników BricsCAD. Zobaczmy, jakie aktualizacje i ulepszenia wprowadzili nasi partnerzy programistyczni, aby uzupełnić cywilne i geodezyjne przepływy pracy BricsCAD V24.
Te aplikacje cywilne i geodezyjne są jednymi z wielu aplikacji innych firm obsługiwanych przez BricsCAD, a nasi programiści pracują nad poprawą ich funkcjonalności i dotrzymują kroku naszym nowym funkcjom wprowadzanym w każdej wersji.
Śledź nas w mediach społecznościowych
