Zoeken
2D schetsen3D Modelleren
DWTs - why you should be using them - Tuesday Tips
Door Rose Barfield 3 min 28 september 2020
DraWing Template files (DWTs) set certain drawing aspects: layers, text styles, units, etc. Creating a DWT means you only need to set your preferences once.
What is a drawing template (DWT)?
A template describes the settings for your drawing. Use templates to save style settings for layers, text styles, units, view style and etc.
How to save a drawing template?
To save a drawing template:
  1. Set all your preferences and settings exactly the way you want. For me this meant changing the facets, the view style, the units and the grid visibility.
  2. Enter SaveAs.
  3. Select the Drawing Template (.dwt) option.
  4. Enter a sensible name.
  5. For easy access save it to the Templates folder: C :\Users\ USER_NAME \AppData\Local\Bricsys\BricsCAD\V20x64\en_US\Templates.
    Use the TemplateFolder command to locate the file path quickly on your computer.
How to access a drawing template?
To access a saved dwt file:
  1. Launch BricsCAD.
  2. On the start page, on the top-left corner there is a blue box with a +. Below it is a drop-down menu with the text "Template...". Click this.DWTs - why you should be using them- start page
  3. Choose the template you require from the drop-down menu.DWTs - why you should be using them- template-options
Can't find your DWTs?
Make sure that your .dwt file is saved to the Templates folder: C :\Users\ USER_NAME \AppData\Local\Bricsys\BricsCAD\V20x64\en_US\Templates.
Can I open my AutoCAD® DWT files with BricsCAD®?
Yes you can open  AutoCAD® DWTs with BricsCAD! Things like layers, grid and units transfer over effortlessly, so there is no need to worry about creating lots of new files if you switch to BricsCAD.
In fact, we encourage you to test it for yourself:download the 30-day, free trial and open your existing drawing templates and .dwg files in BricsCAD. You'll be impressed at how quickly you can be up and running. If you're not happy with the results, send us a support request and we'll do everything we can to make your transition to BricsCAD effortless.
More Tips:
Rose Barfield
door Rose Barfield - CAD User Experience & Interface Design Specialist
LinkedIn logo (b&w)
Rose is verantwoordelijk voor het nemen van gebruikersfeedback en het verbeteren van het BricsCAD-product. Voordat ze bij BricsCAD kwam, was ze een CAD-gebruiker en werkte ze in de automobiel-, ruimtevaart- en defensie-industrie als technisch illustrator. Ze vindt het heerlijk om uit te vinden hoe dingen werken, ze uit elkaar te halen en (hopelijk) weer in elkaar te zetten.
23 juli 2024 3 min
Polyline Editing in BricsCAD
15 juli 2024 3 min
Volg ons op sociale media
