Zoeken
2D schetsen
Arrays - Tuesday Tips
Door Rose Barfield 6 min 22 maart 2021
Arrays in BricsCAD
Did you know, there are 3 types of Array in BricsCAD. In this post we look at what arrays are, how they work, why you should use them and how to edit them.
What is an Array?
Simply put: an array is just an arrangement of entities (objects) that are repetitively space in a rectangular or circular shape, or arranged along a path. Arrays are super useful for creating copies at set intervals. They work in both 2D and 3D.
In BricsCAD there are 3 types of Array:
  • Array Rectangle
  • Array Polar
  • Array Path
Rectangular Array
A rectangular array copies entities (objects) at uniform intervals in a 2D or 3D grid formation. Columns, rows, and levels travel along the X, Y and Z axes respectively.
Arrays- arrayrec
Use the ARRAYRECT command to create a rectangular array.
Polar Array
A polar array copies, entities (objects) at uniform intervals in a circular formation. You can change the fill angle (the percentage of the circle), add rows (adds concentric rings) and levels (the items increase along the Z-axis). In addition, you have to option to rotate the entity or to keep all items oriented in the same direction.
Arrays- arraypolar
Use the ARRAYPOLAR  command to create a polar array.
Path Array
A path array arranges entities (objects) at uniform intervals along a path. You can rows (rows parallel to the current line) and levels (the items increase along the Z-axis).
Arrays- arraypath
Use the ARRAYPATH command to create an array along a path.
More options
Whilst creating arrays you will be given a number of options. I encourage you to experiment and see what happens. Here are some of the key options:
Align items (Array Path)
Choose whether to align each item tangent to the path's direction. Alignment is relative to the first item's orientation.
  • Yes -- each item is placed tangent to the path direction.
  • No -- each item keeps the orientation of the first item.
Arrays- align
Angle between (Array polar)
The angle spacing between items.
Arrays- angle
Columns (Array Rectangle)
Specifies the number of columns (items in the Y direction) and the spacing.
Arrays- col
Fill angle (Array polar)
The angle between the first and the last item. Use negative values to travel clockwise and positive values to travel counterclockwise.
Arrays- fillangle
Levels
The number of levels in an array (items in the Z direction) and the spacing.
Arrays- levels
Method (Array Path)
You have two options:
  • Divide -- distributes a specified number of items evenly-spaced along the path
  • Measure -- places a sufficient number of items along the path, separated by a given distance.
Arrays- method
Items
Specifies the number of items or the distance between items. (With a path array this is different, depending on the setting chosen for Method).
Rows
The number of rows in the array, the distance between them and the incremental elevation.
Rectangular array -- the number of items along the y axis.
Arrays- row rec
Path array -- the number of items the move along the x/y plane.
Arrays- arraypath (1)
Polar array -- the number of entities that radiate out from the center of the array.
Arrays- row polar
Rotate (Array polar)
Chose whether the item rotates as it moves around the array or stays in the same orientation.
Arrays- rotate
Tangent direction (Array Path)
Determines how the items are aligned relative to the starting direction of the path.
Arrays- tangent
Z direction (Array Path)
Choose whether to maintain the items' original Z direction or to bank the items naturally along a 3D path, similar to the Align items option.
Arrays- z dirrection
What about Associative Arrays?
If you selected create associative array, you can still edit the array once you've created it. With a path array that means that, if you edit the path, the array will automatically update to follow it. You can edit the number of rotations and the height of a helix, even after the array has been created.
Editing Arrays
You have a few options for editing existing arrays.
Edit Array with the Properties panel
A quick and accurate way to edit an array is with the Properties panel. First, select the array you wish to edit. Then adjust the values in the Properties panel, as required.
Arrays- properties panel
Edit Arrays with the Quad
YOu can also edit arrays dynamically using the quad. To edit an existing array, hover over an array, hold Ctrl, and open up the Quad. A selection of array-specific options will display that allows you to change the rows, columns, level, source point, and even rotate, move and delete entities within an array.
Arrays- quad
Did you know?
You can enter negative values into the properties panel to achieve arrays in the negative direction!
More Tips:
Rose Barfield
door Rose Barfield - CAD User Experience & Interface Design Specialist
LinkedIn logo (b&w)
Rose is verantwoordelijk voor het nemen van gebruikersfeedback en het verbeteren van het BricsCAD-product. Voordat ze bij BricsCAD kwam, was ze een CAD-gebruiker en werkte ze in de automobiel-, ruimtevaart- en defensie-industrie als technisch illustrator. Ze vindt het heerlijk om uit te vinden hoe dingen werken, ze uit elkaar te halen en (hopelijk) weer in elkaar te zetten.
22 augustus 2024 3 min
Superior Rebar Detailing with Probar 2D for BricsCAD®
Discover superior rebar detailing with Probar 2D for BricsCAD®, an innovative rebar detailing software transforming structural engineering CAD workflows. Learn how BricsCAD and Probar 2D enhance efficient rebar detailing and reinforcement bar detailing across diverse structural projects.
Volg ons op sociale media
