Ieškoti
2D patarimai3D patarimaiBIM TipsBIM BricsCAD BIMBricsCAD Ultimate
How to use Quick Draw in BricsCAD® BIM
Autorius Rose Barfield 2 min. 2023 m. vasario 20 d.
How to use BIMQUICKDRAW in BricsCAD BIM
If you ever opened up architectural CAD software and thought “, Why does this have to be so hard? Can’t it be more like a video game?” you’re in luck! BricsCAD® offers a unique wall and floor tool: Quick Draw (BIMQUICKDRAW).
What is Quick Draw?
The BIMQUICKDRAW command lets you quickly create and edit rectangular and L-shaped rooms and buildings. The room shape is previewed in blue. If you’ve ever played the Sims™, you’ll find the command quite familiar.
How to use the BIMQUICKDRAW command
bimquickdraw GIF in BricsCAD BIM
  1. Pick a starting point.
    bimquickdraw in BricsCAD BIM and BricsCAD Ultimate
  2. Drag the cursor and click to define the room’s footprint.
  3. (Optional) Place the Quickdraw cursor inside the existing building to create more rooms.
    bimquickdraw 2
  4. (Optional) To add a floor or flat roof to the building, click the plus arrow and select from the options.
    bimquickdraw 3
Quick Draw tips!
Here are some extra good-to-know tips:
• To remove a section of a wall from the existing room, first, align the Quickdraw cursor with an existing wall at the inner side of the building. Then click and drag the cursor outside of the existing building. The wall highlighted in red will automatically be deleted, and an L-shaped room will be created.
• You can also use Quick Draw to convert a 2D floor plan into a building.
• Use the command panel to specify the settings for the BIMQUICKDRAW command
What license level do I need to access the BIMQUICKDRAW command?
The BIMQUICKDRAW command is available starting from BricsCAD® BIM. If you purchase BricsCAD BIM or BricsCAD® Ultimate, you will have access to this command.
Have you tried Quick Draw and have some ideas or suggestions?
Fantastic! We love hearing your thoughts on BricsCAD® – all feedback is welcome, whether good or bad. The best way to let us know what you think about BricsCAD or features like Quick Draw is to send us a support request and our support team will be happy to help.
Explore BricsCAD
Rose Barfield
nuo Rose Barfield - CAD User Experience & Interface Design Specialist
LinkedIn logo (b&w)
Rose yra atsakinga už naudotojų atsiliepimus ir BricsCAD produkto tobulinimą. Prieš ateidama į BricsCAD ji pati buvo CAD naudotoja ir dirbo automobilių, aviacijos ir gynybos pramonėse technine iliustruotoja. Jai patinka sužinoti, kaip viskas veikia, tai išardyti ir (tikėkimės) vėl sudėti.
Sekite mus socialiniuose tinkluose
