Search
2D Drafting
Dynamic block editing with Dynamic Grips - Tuesday Tips
By Kelsey Grant 3 min 11 Oktober 2021
If you come from an AutoCAD® design environment, you may be familiar with Dynamic Blocks. BricsCAD offers some Dynamic block editing capabilities with Dynamic Grips. Read on to see what you can do with Dynamic Grips in BricsCAD.
1) Flip Grip
Flip Grip allows you to flip a dynamic block on both the horizontal and the vertical axis very simply.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Flip-Grip-1
Dynamic block editing with Dynamic Grips - Tuesday Tips- Flip-Grip-2-1
2) Rotate Grip
Here you can see the Rotate Grip in action, moving this table and chairs block to the desired angle.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Rotate-Grip-1
3) Visibility Grip
The Visibility Grip allows you to choose your desired block, and also which perspective you would like to view it from. Here you can see a car block with a variety of model and perspective options.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Visibility-Grip-1
4) Stretch Grip
With one click you can stretch a dynamic block to your desired dimensions. This stretching is done in incremental lengths defined in your dynamic block.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Stretch-Grip-1
5) Stretch Grip & Array
The stretch grip also works in combination with the Array tool and can be seen in action below. As the table block is lengthened using the Stretch Grip, the chairs array alongside it, saving you time and effort.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Stretch-Grip-Array-1
6) Lookup Grip
Using the Lookup Grip makes adjusting the size of your dynamic block quick and easy. Below you can see the Grip being used to change the size of a table and chairs block.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Lookup-Grip-1
7) Block Table Grip
This Grip is useful when working with dynamic blocks like windows, as in the video below. You can swiftly change the size of your block with minimal disruption to your workflow.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Block-Table-Grip-2
8) Scale Grip
The Scale Grip works on dynamic blocks to increase their size whilst keeping the correct scale, in increments. You can see this taking place on a round table and chairs block in the clip below.
Dynamic block editing with Dynamic Grips - Tuesday Tips- Scale-Grip
You've now seen the most commonly used Grip functions when working with Dynamic Blocks in BricsCAD. You'll be up to speed and at full productivity in no time at all when switching from other CAD software to BricsCAD. Grip features and other handy BricsCAD features will help you along the way!
Take a look at the full video.
Try BricsCAD Free
Get BricsCAD free for 30-days
Permanent or subscription licenses that work in all languages, in all regions.
More Tips:
Kelsey Grant - Author
by Kelsey Grant - Marketing Content Specialist
LinkedIn logo (b&w)
Kelsey is our Marketing Content Specialist at Bricsys, based in the UK. Coming from a background in Social Media to CAD, she takes pride in crafting clear and engaging content, helping guide BricsCAD users to create great things!
17 September 2024 3 min
10 September 2024 3 min
BricsCAD Partner Apps for Civil and Survey Workflows
At Bricsys, we provide a solid foundation for our specialist survey and civil app developers to create specialist civil and survey tools that deliver robust and efficient workflows for BricsCAD users. Let’s see what updates and improvements our various developer partners have made to complement BricsCAD V24's civil and survey workflows.
These civil and survey applications are among multiple third-party applications supported by BricsCAD, with our developers working to improve their functionality and remain on pace with our new features introduced with every release.
9 September 2024 4 min
Embracing Digital Transformation in the Construction Industry with Bricsys 24/7®
The construction industry continually evolves, and digital transformation is reshaping how teams manage projects, communicate, and handle project documentation. When embracing digital solutions for construction projects, a common data environment (CDE) like Bricsys 24/7 is an excellent place to start. With a significant variance in the level of digital adoption across the industry, embracing and leveraging digital tools can help firms differentiate themselves by elevating operational efficiency and improving project outcomes.
Follow us on social media
