Search
2D Drafting3D Modelling
Speed Up Your CAD Workflow With The Quad - Tuesday Tips
By Rose Barfield 4 min 19. aprill 2021
The Quad is a unique feature to BricsCAD that speeds up your CAD workflow by putting your most used and needed commands right under your cursor.
With the Quad, it's simple and easy to execute complex commands that normally require several clicks, options, and dialog boxes. For users coming from other platforms, this little guy may feel surplus to requirements, but I promise you, after using it for just a few hours, you'll be wondering how you ever worked without it.
Don't believe me?
Just check this side by side comparison:
Watch video on YouTube
How does it work?
It might sound silly, but, first: check it's switched on! Head over to the bottom right-hand corner and click QUAD or simply hit F12.
Now, just hover over a line, solid, face or border and let the Quad recommend the commands. No need to search around the different panels or type in the ribbon. You can execute an entire range of commands, from the Quad-based command palette, with a single click. You can also activate the Quad with a right-click.
The more you use the Quad the better it gets! The Quad uses machine learning to adapt to your most frequently accessed commands.
2 tricks you might not know
Repeat a command
To repeat a command there is no need to hover, just right-click. This goes for any command. Just when you thought it couldn't get any faster!
The right-click menu
Instead of bringing up the Quad with a right-click, you can access your beloved right-click menu. Simply hold down the right-mouse button slightly longer (>250 milliseconds) and it will appear.
Customization
There are tons of ways to customize the Quad.
Speed Up Your CAD Workflow With The Quad- settings-2-743x800
Here are some of my favorites:
Size
Speed Up Your CAD Workflow With The Quad- Quad sizes
The Quad with small and large icon sizes
Find some of the icons a little bit too tiny, or think the Quad is too large and intrusive, no problem, just change the size of the Quad in the settings.
Customizable menus
Tell the Quad what it can and can't show you. When I first started using the Quad it kept recommending a command I never used. I would accidentally click it and become frustrated as it eagerly suggested I used this command again and again. All I had to do was enter BricsCAD customization, locate the command and turn the recommendation off (right click 'delete'). Problem solved!
Speed Up Your CAD Workflow With The Quad- custom-800x643
Quad most recent items
Customize the number of recently used items shown in The Quad. If you always use the same 3 or 4 commands: set it higher. Want to Quad to make more intelligent suggestions? Lower the value.
Ready to cut your work time?
Easy to try, easy to buy, easy to own. That's BricsCAD. Freedom of choice, plus perpetual (permanent) product licenses that work with all languages, in all places. You'll love what we've built for you with BricsCAD.
More Tuesday Tips:
Rose Barfield
LinkedIn logo (b&w)
17. september 2024 3 min
10. september 2024 3 min
BricsCAD Partner Apps for Civil and Survey Workflows
At Bricsys, we provide a solid foundation for our specialist survey and civil app developers to create specialist civil and survey tools that deliver robust and efficient workflows for BricsCAD users. Let’s see what updates and improvements our various developer partners have made to complement BricsCAD V24's civil and survey workflows.
These civil and survey applications are among multiple third-party applications supported by BricsCAD, with our developers working to improve their functionality and remain on pace with our new features introduced with every release.
9. september 2024 4 min
Embracing Digital Transformation in the Construction Industry with Bricsys 24/7®
The construction industry continually evolves, and digital transformation is reshaping how teams manage projects, communicate, and handle project documentation. When embracing digital solutions for construction projects, a common data environment (CDE) like Bricsys 24/7 is an excellent place to start. With a significant variance in the level of digital adoption across the industry, embracing and leveraging digital tools can help firms differentiate themselves by elevating operational efficiency and improving project outcomes.
Follow us on social media
