Search
3D Modelling
BricsCAD Tuesday Tips: Rendering materials
By Rose Barfield 5 min 13. jaanuar 2020
Tuesday Tips - Everything you need to know about Render Materials in BricsCAD
As standard, BricsCAD comes with a large number of free materials and textures but even with all these materials at your fingertips, you might still want to add your materials to the library. The good news is: you can create and import your materials into BricsCAD!
Free materials and textures
Although you can create your texture from scratch, it's often easier to simply download them. Here's a useful list of sites where you can download free materials and textures:
  • cc0textures -- 700+ free, public domain textures and growing.
  • Texture Heaven -- Huge selection of high-quality materials specifically building/natural textures.
  • Plain Textures -- Don't let the name fool you! this website has just about any texture; food, rusted signage, stormy skies...
  • PBR Materials -- You need to create an account, but there are 100s of free downloads
  • Poliigon -- Large variety of well-prepared textures at different resolutions including rendering maps.
  • Arrowway Textures -- Range of building material textures, all at high resolution.
  • Texture library -- Basic website, but has a good range of textures.
  • Free Stock Textures -- More Graphic design-focused, but useful for more creative projects.
  • 3DXo -- Also has some free, 3D models for download!
There are also plenty of places where you can download free 2D and 3D models. Many of these sites offer free textures and render materials and often the models come with textures preloaded!
How to create your custom materials in BricsCAD:
1. Enter MATERIALS into the Command line or navigate to Materials in the Drawing Explorer.
2. Set the values for the material.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- texture-1024x748
3. Set the color or add a raster image and a texture map, if relevant; .bmp, .jpg, .jpeg, .png, or gif.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- color-1024x748
4. Give the material a name.
5. Right-click the material name and select 'Add Material(s) to Library' from the dropdown menu.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- add to Ibrary-1024x746
The material will now be available to you in the 'User Defined' category of the Render Materials panel. Learn more about creating your own Render Materials in BricsCAD.
How to add a material to your model in BricsCAD:
The easiest way to add the newly created material to a model:
1. Open the Render Materials Panel (New for V20).
2. Click the materials and drag and drop the material onto your model.
Hold Ctrl to assign the material to a complete object or simply drag and drop the material to each face in turn.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- wallpaper
If the material is local (only saved to this drawing), you can find the material under the 'In drawing' section of the Render Materials panel. If the Material is assigned to the Library you will find it under the 'User defined' section.
You can also use the Properties panel. Select an object and assign the material using the 'Materials' drop-down menu under the 3D Visualization section.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- drop down
How to assign a material to a layer:
1. Use the Properties Panel. Make sure that the object(s) is assigned to the correct layer and that the 'Materials' drop-down menu under the 3D Visualization section is set to 'By Layer'.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- by layer
2. Open the Layers panel.
3. Under the 'Material' column, use the drop-down menu to assign a material to all the objects on a given layer.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- drop-down layer
Where do you download free textures and materials?
Are there any great websites I've missed off the list above? Add your favorite website in the comments below!
Download BricsCAD free for 30-days
Get started with BricsCAD
Permanent or subscription licenses that work in all languages, and all regions.
Disclaimer: These links are being provided as a convenience and for informational purposes only; they do not constitute an endorsement or approval by Bricsys of any of the products, services, or opinions of the corporation or organization, or individual. Bricsys bears no responsibility for the accuracy, legality, or content of the external site or for that subsequent links. Contact the external site for answers to questions regarding its content.
More Tuesday Tips:
Rose Barfield
LinkedIn logo (b&w)
17. september 2024 3 min
10. september 2024 3 min
BricsCAD Partner Apps for Civil and Survey Workflows
At Bricsys, we provide a solid foundation for our specialist survey and civil app developers to create specialist civil and survey tools that deliver robust and efficient workflows for BricsCAD users. Let’s see what updates and improvements our various developer partners have made to complement BricsCAD V24's civil and survey workflows.
These civil and survey applications are among multiple third-party applications supported by BricsCAD, with our developers working to improve their functionality and remain on pace with our new features introduced with every release.
9. september 2024 4 min
Embracing Digital Transformation in the Construction Industry with Bricsys 24/7®
The construction industry continually evolves, and digital transformation is reshaping how teams manage projects, communicate, and handle project documentation. When embracing digital solutions for construction projects, a common data environment (CDE) like Bricsys 24/7 is an excellent place to start. With a significant variance in the level of digital adoption across the industry, embracing and leveraging digital tools can help firms differentiate themselves by elevating operational efficiency and improving project outcomes.
Follow us on social media
