Buscar
Dibujo 2DCivil y Topografía
Find Outliers in BricsCAD® Pro - Working Smarter with BricsCAD
Por The Bricsys Team 3 min 25 de mayo de 2023
We have made it easier to find outliers in BricsCAD Pro V23.2 and enhanced the FINDOUTLIERS command - let's catch you up!
Valid region
This example begins with a land surveying DWG file – the 2D results of a scanned terrain. We want to place all the geometry around the origin to clean up the drawing.
null
Navigate to the Manage Tab in the ribbon and launch the FINDOUTLIERS command.
null
Tip! The tips panel provides you with some handy tips and tricks about how to use the FINDOUTLIERS command.
null
Specify a valid region.
Most of the geometry in this file is far from the valid region around the origin. If needed, change the valid region.
null
Inspecting Outliers
When you are happy with the valid region, you can inspect the outliers.
You can view outliers in the list view, where they are grouped into clusters.
In this example, you can see three clusters of outliers and one individual outlier. The bulk of this model consists of about 13,000 outliers, so you need to move this around the model's origin – which you can do with a single click.
null
Use the move function to move these outliers into the valid region.
Use the zoom function to inspect any remaining individual outliers.
Remove irrelevant outliers as needed.
Mover
For this example, you can see a group of geometry relevant to the model, so you need to move it to the origin.
null
You can manually move this geometry to the origin by choosing where to move the objects.
null
Once you are happy with the configuration, you can end the commands.
And that's it – you have centered all geometry around the origin in just a few clicks!
¡Ver el vídeo!
Check out the YouTube walkthrough to watch the FINDOUTLIERS command in action!
Have you tried the enhanced FINDOUTLIERS command and have some ideas or suggestions?
¡Fantástico! Nos encanta escuchar sus opiniones sobre BricsCAD®: todos los comentarios son bienvenidos, ya sean buenos o malos. La mejor manera de hacernos saber lo que piensa acerca de BricsCAD es enviarnos una solicitud de soporte; nuestro equipo de soporte estará encantado de ayudarle.
¿Quiere más consejos y trucos de BricsCAD?
Si tiene curiosidad sobre qué más puede hacer en BricsCAD, consulte nuestro canal de YouTube para obtener más información sobre las funciones y los comandos de BricsCAD o eche un vistazo al resto del blog de Bricsys.
15 de mayo de 2023 7 min
Artificial Intelligence in BricsCAD® Lite & Pro – What's the Point? Checking drawing health
In the previous blog post, we explained how automation and artificial intelligence are baked into key processes in BricsCAD® BIM to speed up your building design workflows. At Bricsys, we apply similar techniques across our BricsCAD® product portfolio, so we take the same approach with our flagship products BricsCAD® Lite and BricsCAD® Pro.
Síganos en las redes sociales
