Buscar
Dibujo 2D Modelado 3D
Speed Up Your CAD Workflow With The Quad - Tuesday Tips
Por Rose Barfield 4 min 19 de abril de 2021
The Quad is a unique feature to BricsCAD that speeds up your CAD workflow by putting your most used and needed commands right under your cursor.
With the Quad, it's simple and easy to execute complex commands that normally require several clicks, options, and dialog boxes. For users coming from other platforms, this little guy may feel surplus to requirements, but I promise you, after using it for just a few hours, you'll be wondering how you ever worked without it.
Don't believe me?
Just check this side by side comparison:
Watch video on YouTube
How does it work?
It might sound silly, but, first: check it's switched on! Head over to the bottom right-hand corner and click QUAD or simply hit F12.
Now, just hover over a line, solid, face or border and let the Quad recommend the commands. No need to search around the different panels or type in the ribbon. You can execute an entire range of commands, from the Quad-based command palette, with a single click. You can also activate the Quad with a right-click.
The more you use the Quad the better it gets! The Quad uses machine learning to adapt to your most frequently accessed commands.
2 tricks you might not know
Repeat a command
To repeat a command there is no need to hover, just right-click. This goes for any command. Just when you thought it couldn't get any faster!
The right-click menu
Instead of bringing up the Quad with a right-click, you can access your beloved right-click menu. Simply hold down the right-mouse button slightly longer (>250 milliseconds) and it will appear.
Customization
There are tons of ways to customize the Quad.
Speed Up Your CAD Workflow With The Quad- settings-2-743x800
Here are some of my favorites:
Size
Speed Up Your CAD Workflow With The Quad- Quad sizes
The Quad with small and large icon sizes
Find some of the icons a little bit too tiny, or think the Quad is too large and intrusive, no problem, just change the size of the Quad in the settings.
Customizable menus
Tell the Quad what it can and can't show you. When I first started using the Quad it kept recommending a command I never used. I would accidentally click it and become frustrated as it eagerly suggested I used this command again and again. All I had to do was enter BricsCAD customization, locate the command and turn the recommendation off (right click 'delete'). Problem solved!
Speed Up Your CAD Workflow With The Quad- custom-800x643
Quad most recent items
Customize the number of recently used items shown in The Quad. If you always use the same 3 or 4 commands: set it higher. Want to Quad to make more intelligent suggestions? Lower the value.
Ready to cut your work time?
Easy to try, easy to buy, easy to own. That's BricsCAD. Freedom of choice, plus perpetual (permanent) product licenses that work with all languages, in all places. You'll love what we've built for you with BricsCAD.
More Tuesday Tips:
Rose Barfield
por Rose Barfield - CAD User Experience & Interface Design Specialist
LinkedIn logo (b&w)
Rose es responsable de recibir los comentarios de los usuarios y mejorar el producto BricsCAD. Antes de llegar a BricsCAD, era usuaria de CAD y trabajó en las industrias automotriz, aeroespacial y de defensa como ilustradora técnica. Le encanta descubrir cómo funcionan las cosas, desmontarlas y (con suerte) volver a montarlas.
6 de noviembre de 2024 4 min
17 de septiembre de 2024 4 min
Personalización de tipos de línea en BricsCAD
La creación de tipos de línea personalizados en BricsCAD puede mejorar significativamente el detalle y la claridad de sus dibujos. Ya sea que esté trabajando en planos de ingeniería complejos o presentaciones de diseño simples, comprender cómo crear sus propios tipos de línea puede darle a sus proyectos una ventaja profesional. Siga esta guía paso a paso para aprender a crear tipos de línea simples y complejos en BricsCAD.
10 de septiembre de 2024 3 min
Aplicaciones de socios de BricsCAD para flujos de trabajo civiles y topográficos
En Bricsys, proporcionamos una base sólida para que nuestros desarrolladores de aplicaciones civiles y topográficas especializadas creen herramientas civiles y de topografía especializadas que brinden flujos de trabajo robustos y eficientes para los usuarios de BricsCAD. Veamos qué actualizaciones y mejoras han realizado nuestros diversos socios desarrolladores para complementar los flujos de trabajo civiles y topográficos de BricsCAD V24.
Estas aplicaciones civiles y topográficas se encuentran entre las múltiples aplicaciones de terceros compatibles con BricsCAD, y nuestros desarrolladores trabajan para mejorar su funcionalidad y mantenerse al día con nuestras nuevas funciones introducidas con cada versión.
Síganos en las redes sociales
