Search
BricsCAD V232D Tips3D Tips
What's New for V23? ARRAYDETECT
By Rose Barfield 3 min 5 January 2023
Have you ever imported a drawing to find that the arrays have exploded? If exploding arrays are a recurring issue, then you need the ARRAYDETECT command!
What is the ARRAYDETECT command?
ARRAYDETECT converts entities in uniform, rectangular patterns into arrays, even if the designs are incomplete.
Why ARRAYDETECT?
After some research, we discovered that our users weren’t aware that the ARRAYDETECT feature was available since it used to be part of the BLOCKIFY command. So, we decided to bring ARRAYDETECT to the forefront, giving it its dedicated order!
How to use the ARRAYDETECT command
If you want to test out the new ARRAYDETECT command, there are two ways you can go about it.
Option 1: Single sets of entities
  • Open a drawing with exploded rectangular arrays or with entities that have been copied at uniform, rectangular intervals
  • Enter ARRAYDETECT
  • Select the area for BricsCAD® to search for arrays, press Enter
  • Choose the “Autodetect single entity arrays” option
  • In the command panel, pick the arrays you want to convert
  • Click “Convert # patterns.”
Option 2: Collections of entities
  • Open a drawing with exploded arrays or with entities that have been copied at uniform, rectangular intervals
  • Enter ARRAYDETECT
  • Choose the “select source Entities” option
  • Select a set of entities that represent one copy of the array, press Enter
  • In the command panel, click “Convert one pattern.”
We have also created a YouTube tutorial explaining how to use ARRAYDETECT just for you!
Get started with BricsCAD today!
Buy BricsCAD or download the 30-day free trial now and discover how you can accelerate your time to deliverable with BricsCAD.
Have you tried out the ARRAYDETECT feature and have any ideas or suggestions?
Fantastic! We love hearing your thoughts on BricsCAD® – all feedback is welcome, whether good or bad. The best way to let us know what you think about BricsCAD or features like ARRAYDETECT is to send us a support request, and our support team will be happy to help.
What else is new in V23?
If you’re curious about what else is new in V23, check out our YouTube channel where you can learn more about BricsCAD’s features and commands, or take a peek at the rest of the Bricsys blog.
Rose Barfield
LinkedIn logo (b&w)
Follow us on social media
