Suche
2D Zeichnen3D Modellierung
New for BricsCAD V23 – The Tips Panel
Von Rose Barfield 4 min 29. November 2022
BricsCAD V23 What’s New
The Tips Panel has had a revamp for BricsCAD V23. This will help both new and existing users to get started faster and easier in a familiar, intuitive workspace.
Maybe you’re thinking “but that’s only for new users” or “I’m a pro, I know the tips and tricks”, well, keep on reading and see how the new Tips Panel is more helpful than ever!
What is the Tips Panel?
The Tips panel is located to the left of BricsCAD and is switched on, in all workspaces, when you first start BricsCAD. It gives you hints and tips based on the current workspace and the command in-use.
What’s new for V23?
The Tips panel has been extended from 64 page to a massive 205. It has also become more interactive with more detailed information, and there are new, workspace-specific tips for Paper Space, the Mechanical workspace. There is also the all-new Civil workspace.
Why did we make the changes?
When we watched experienced CAD users using BricsCAD for the first time, we noticed they liked the old Tips Panel and tried to explore the panel. However, here the information was limited, and it lacked full interactivity.
null
How to use the Tips Panel
You have two options to test out the new Tips Panel.
Option 1: Interactive
  1. Open BricsCAD in your favorite Workspace
  2. Click the links on the page
  3. Start exploring
Option 2: Responsive
  2. Activate your favorite command: BLOCKIFY, ARRAY, LINE, etc.
  3. Watch the Tips Panel change dynamically, to display hints relevant to the command in-use
null
I’m an advance CAD user, why do I need the Tips Panel?
There are several sections in the Tips Panel in the Drafting workspace created specifically for experienced users: New for V23 and Power Users. Under these sections, you’ll find hints and tips to help you get the most from BricsCAD V23.
In other workspaces, you’ll notice a yellow ‘New for V23’ next to new commands on the homepage of the Tips Panel. This helps users get started with BricsCAD V23’s new features straight away.
null
I’ve got what I need from the Tips Panel, how do I turn it off?
To close the Tips Panel, either click the X in the top-right of the panel, or right-click anywhere on the BricsCAD UI, for example the ribbon and select Panel > Tips from the menu.
How do I get the Tips Panel back?
To open the Tips Panel, right-click anywhere on the BricsCAD UI, for example the ribbon and select Panel > Tips from the menu.
‘I’ve tested the Tips panel, and I have some ideas; how can I get in touch?’
We love to hear your thoughts about how to make BricsCAD perform better for users. Send us a support request to tell us your ideas and an expert from our team will be happy to help.
null
Did you see the Bricsys Digital Summit 2022? Catch up on-demand
The Bricsys Digital Summit 2022 is now on-demand. Catch up on all the latest innovative tools in BricsCAD V23 and advances within Bricsys 24/7, the powerful common data environment (CDE) for the AEC sector. Watch our speakers and CAD product experts give live demos and products insights across 25+ break-out sessions. And find out how you can build better with Bricsys. 
Start with BricsCAD V23, take a free 30-day CAD trial today
Why not discover the BricsCAD difference for yourself? Download your free trial today.
Rose Barfield
von Rose Barfield - CAD User Experience & Interface Design Specialist
LinkedIn logo (b&w)
Rose ist dafür verantwortlich, das Feedback der Benutzer aufzunehmen und das BricsCAD-Produkt zu verbessern. Bevor sie zu BricsCAD kam, war sie selbst CAD-Anwenderin und arbeitete in der Automobil-, Luftfahrt- und Verteidigungsindustrie als technische Illustratorin. Sie liebt es, herauszufinden, wie Dinge funktionieren, sie auseinanderzunehmen und (hoffentlich) wieder zusammenzusetzen.
6. November 2024 4 min
17. September 2024 3 min
10. September 2024 3 min
BricsCAD Partner Apps for Civil and Survey Workflows
At Bricsys, we provide a solid foundation for our specialist survey and civil app developers to create specialist civil and survey tools that deliver robust and efficient workflows for BricsCAD users. Let’s see what updates and improvements our various developer partners have made to complement BricsCAD V24's civil and survey workflows.
These civil and survey applications are among multiple third-party applications supported by BricsCAD, with our developers working to improve their functionality and remain on pace with our new features introduced with every release.
Folgen Sie uns in den sozialen Netzwerken
